Here's the basic information:
NUC 8i7HVB
Version J68196-602
MSWin 11 Pro 64bit v22H2
BT DRIVER: MS10.0.22621 6/21/2006
BT Device Id:
BTH\MS_BTHPAN\6&BC37F54&082
I'm having chronic problems with pairing and connecting a variety of external devices that use Bluetooth.
The MS driver that shows up is dated 2006. Is there an Intel BT driver that will work better?
Any other recommendations for troubleshooting?
Thanks for any ideas.
Installs Intel® Wireless Bluetooth® version 22.190.0. Driver version varies depending on the wireless adapter installed and Installs the Intel® PROSet/Wireless Software for Bluetooth® technology driver for Intel® NUC using Windows® 10 64-bit. If this will not work then you can install Bluetooth Driver Installer and Intel® Wireless Bluetooth®. Try once with this may be this will work well for you.
1. Please verify that that both antennas are connected to WiFi adapter.
2. The Bluetooth driver installed in your NUC is the latest one. Please verify that you have also the latest WiFi driver installed.
Leon
