Community
cancel
Showing results for
Search instead for
Did you mean:
DMich8
Building a nuc for plex server
Jump to solution
what do you guys think about
https://www.newegg.ca/Product/Product.aspx?Item=N82E16856102205 Intel NUC (Next Unit of Computing) BLKNUC7i7DNK1E Mini
https://www.newegg.ca/Product/Product.aspx?Item=9SIA9ZP6D16438 SAMSUNG 16G 288Pin DDR4 SO-DIMM 2Rx8 DDR4 2400 (PC4 19200) Laptop Ram Memory
https://www.newegg.ca/Product/Product.aspx?Item=9SIA7RD7DM7234 SAMSUNG 970 EVO M.2 2280 500GB PCIe Gen3. X4, NVMe 1.3 64L V-NAND 3-bit MLC Internal Solid State Drive (SSD) MZ-V7E500BW
Will have this for plex server multiple transocding possible .
Ram was very limited so im not sure !
Community Manager
Hello, TwistedEndz. Thank you very much for sharing your issue with the Intel Communities Team. I will be more than glad to assist you.
Allow me to share with you these links where the requirements of a plex server are explained:
https://support.plex.tv/articles/200375666-plex-media-server-requirements/ https://support.plex.tv/articles/200375666-plex-media-server-requirements/
https://www.youtube.com/watch?v=8xwVAuubmsM https://www.youtube.com/watch?v=8xwVAuubmsM
By checking that information and reviewing the Specifications of the https://ark.intel.com/products/130392/Intel-NUC-Kit-NUC7i7DNKE Intel® NUC7i7DNKE, It reaches the requirements to be a plex server. Please take into consideration that the NUC is intended for home use and not as a server so, we recommend using server hardware for this purpose.
Antony S.
Community Manager
Antony S.
