Hi Everyone
I have a burnt capacitor on an old NUC that I use as a great little work computer and it's an easy fix.
Does anyone know where I could get the schematics for the board so I can get the capacitor value? I don't know where to start I'm afraid. I could obviously go and by another one but it's a personal challenge now!
Cheers
Dan
Dan,
Here's the information that you'll need:
Good luck with the repair attempt - and let us know what happens,
Thanks for your reply Scott
Pictures are attached so hopefully it makes sense. The burnt area is behind SO-DIMM 1 socket as circled.
There's some vapourised track that I can easily repair and the heat reflowed the solder for some of socket legs that I can clean, braid and resolder.
The obviously fried cap is the larger 0602 and I'll also replace the smaller 0402 so I need their vaules to complete the job properly. I may be able work out what values they are but it would be great if it was official. I doubt those cap specs changed in later models so other electrical schematics would probably work fine. They look like they are related to temperature monitoring and subsequent auto fan speed so a bit of trial and error wouldn't blow much else......... hopefully!!!!
Thanks in advance for your time
Dan
I will try to get you an answer Monday or Tuesday...
You're a legend.
Thanks so much Scott
Dan
Hello @Danno320
We hope that the assistance provided by the community has been helpful.
Also, we would like to inform you that due to the Intel® NUC Kit D54250WYKH has been discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website helpful to address your request.
Note: You might need to search for the proper Product Category and click on its "Show more" link if the product is not visible in the top rows.
Andrew G.
Dan,
Wow, I'm so happy
I hate throwing things away that can be repaired so you've made all the difference Scott. Thank you so much.
I'll come back and post pics of the repair so you can see the effects of your input.
If you're ever on the south coast of the UK and find yourself in a place called Arundel I owe you a fish and chips with a beer to wash it down!
I'll be back next week with an update
Thanks again
Dan
Right, I'm finished
I removed the caps and cleaned off the carbonised damaged area. Buzzed out the connections. Tidied up the legs. Replaced the caps with new ones but I exchanged the smaller 0402 with a larger 0602 so it could handle more current due to the damaged track. I also added extra solder to the bridge for the same reason.
Swithched her on and....... she's back!!!
All working as expected.
Thank you again for your help Scott it really is appreciated.
Cheers
Dan
Hi @n_scott_pearson,
Sorry to reach you in this way. Since you retired from Intel I couldn't find your name on Skype or Teams (yes we switched from Skype to Teams now) anymore.
I have a question regarding the capacitor on my NUC. It's NUC8i7HVK (Hades Canyon) and I accidentally ripped off one of its capacitors (see pic below) when I was replacing the thermal paste. I would also like to ask you for help if you can somehow access its schematics to find what model of that capacitor is. Thank you in advance!
Well, that's good to hear - and unusual for this type of issue.
Already answered you in your other posts.
