Intel® NUCs
12307 Discussions
CAN I boost blue tooth range of a NUC Intel® Core™ i7-7567U CPU @ 3.50GHz on win 10 signal breaks too easily ???.....an arieal ??? thanks in anticipation Russ
rbrad13
LeonWaksman
  1. What is your NUC model?
  2. What is the range you are expecting from your Bluetooth? It is open space or you are trying to connect Bluetooth beyond the wall?
Leon
rbrad13
Leon thanks for getting back,
Model is: NUC7i7BNH
Range is within a modern flat/appartment, "modern" in the sense the walls are not brick or concrete.
My iphone range is "miles" better in comparison and never drops in same enviro.
Russ
LeonWaksman
  1. Your NUC is equipped with AC8265 Dual band Wireless Module. This module serves both - WiFi and Bluetooth connections. The Bluetooth in your NUC is per 4.0 specification. Bluetooth 4.0 specification, adopted in 2010, has a theoretical range of up to 200 feet. This is only theoretical range. The Bluetooth is interfered by other wireless devices working in 2.4GHz frequency, by walls and other environmental factors. Practically the Bluetooth range is about 30 feet.
  2. You may improve the Bluetooth range, by using your WiFi in 5GHz band or buying a Bluetooth Extender.
  3. All the above is valid only if there is no hardware failure in your NUC. If your WiFi 2.GHz is working well, than probably there is no hardware problem.
Leon
jlg
I am experiencing similar problems. My NUC is a 8i3BEH.
I have tried switching Wi-Fi to 5G but this has so far not worked.
My NUC is 3 meters away from the connected device, which is immediately turning left from a wall corner.
I'm running Debian GNU/Linux, if it is of any help.
David_V_Intel
Hello rbrad13,
Thank you for posting on the Intel ® communities.
Let me know if you need more assistance.
David V
A Contingent Worker at Intel
David_V_Intel
Hello rbrad13,
Please contact us if you have any additional questions.
David V
