Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
CANBUS for NUC
does anyone know a way of easily integrating CANBUS communication with a NUC?
Andrew
Highlighted
Super User Retired Employee
Can't you just use one of the USB-to-CAN adapters? Like this: https://www.kanda.com/products/Lawicel/CANUSB.html CANUSB - USB CAN bus interface for CAN bus to USB PC Connection
Highlighted
Community Manager
Thanks Scott,
I'm looking for some way to incorporate the CAN card directly onto the NUC rather than a USB or serial type adaptor.
Highlighted
Well, speculatively, there are a number of possibilities that come to mind:
  1. There are serial and i2c outputs on the Customer Solutions Headers on many of the NUCs and you could interface to a separate CAN card using them.
  2. I have seen some PCIe-based CAN cards. It is possible that a version of one of these could be developed that plugs into the NUC's M.2 mPCIe connector.
  3. You could still implement using USB; connecting to one of the internal USB 2.0 headers.
