Community
cancel
Showing results for
Search instead for
Did you mean:
MMuts
CEC with Linux-Scripts
Hello.
I use a NUC 6CAYH for a digital signage application.
The nuc turns the TV on and off on boot/shutdown. I would like to turn it on/off by a script. Is this possible? I installed cec-utils (on Ubuntu), but cec-client -l says "Found devices: NONE"...
Community Manager
Hello mimu88
Thank you for joining the community
I understand that you are looking for assistance on setting up a script to turn on/off the NUC. But I will like to share with you that only operating system supported in the NUC by Intel is Windows® 10, 64-bit*, see the reference link below
https://www.intel.com/content/www/us/en/support/articles/000005628/mini-pcs.html https://www.intel.com/content/www/us/en/support/articles/000005628/mini-pcs.html
However, you can verify your operating system communities for assistance on your situation
Leonardo C.
MMuts
Hello Leonardo.
No, i would like to write a script in Linux which turns the TV on/off by sending CEC-Commands.
The NUC is able to send CEC-commands to the TV on boot and shutdown, but I would like to leave the NUC on and turn the TV on/off with CEC-commands.
Michael
Community Manager
Hello mimu88
Thank you for your response, I this specific case the best way to proceed will be to get in contact with the Linux community for the proper script that you are looking for
Leonardo C.
