Intel® NUCs
12304 Discussions
Can I turn off the front panel illumination in NUC BOXNUC6CAYH?
WSope
Czy można wyłączyć podświetlenie panelu przedniego, najlepiej z poziomu BIOSu?
From the BIOS?
n_scott_pearson
Super User Retired Employee
You can turn off front panel illumination from within BIOS Setup (Visual BIOS). Navigate to Advanced / Power. In the (right-hand) Secondary Power Settings section, set the Button LED and Ring LED parameters to SW Control. This should be enough to keep them off, but you can also set all of the Brightness parameters to Off.
Hope this helps,
