A man from the power-adapter store told me I can use, but I want to have professional advice with arguments. Thank you.
I am sure you are asking about the 7.7A, but, in fact, the voltage is the real issue. In this case, requirement is within 10%, so it should be fine.
P.S. Liking your own posts does nothing for you.
Hahaha) I love you)
Thank you for the answer.
I still waiting an answer from Intel support. They didn't reply yet.
I'm worry about this +0.5V because I'm going to use my NUC 24/7 365days.
Sergey
In official spec here:
https://ark.intel.com/content/www/us/en/ark/products/126147/intel-nuc-kit-nuc8i5bek.html
they say: "DC Input Voltage Supported 12-19 VDC"
12-19 ok but what if 19.5V)
Any suggestions)?
Hello trackbolt
Thank you for posting in the Intel Community.
I agree with n.scott.pearson, on the Technical Product Specification Intel® NUC Products NUC8i3BE/NUC8i5BE/NUC8i7BE (https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/nuc-kits/NUC8i3BE_NUC8i5BE_NUC8i7...) the section 2.2.4.6 Power supply connector page 38 you can find the following statement: "External Power Supply – the board can be powered through a 12-19 V DC connector on the back panel. The back panel DC connector is compatible with a 5.5 mm/OD (outer diameter) and 2.5 mm/ID (inner diameter) plug, where the inner contact is +12-19 (±10%) V DC and the shell is GND. The maximum current rating is 10 A.)".
We recommend using the 12-19 VDC that comes with the Intel® NUC but you should be fine with the 19.5V 7.7A.
Hope this helps.
Leonardo C.
Under Contract to Intel Corporation
Thank you for support!
Hello trackbolt
You are welcome we are glad to help you.
Leonardo C.
