Intel® NUCs
12298 Discussions
Can I use a battery that a little higher than standard voltage to power the PC?
ZJING3
I want to power my mini PC Intel NUC7I7BNH with DC power.
The input range of Intel NUC is 12V~19V. And I have a battery which output is about 19.5V.
Can I use this battery to power my mini PC?
Thank you very much
n_scott_pearson
Super User Retired Employee
The input voltage must be within the range 12-19 (±10%) V DC. This translates to a range of 10.8-20.9 V DC. If your battery can provide a consistent voltage within this range, you should be good to go.
As a separate note, it has been suggested that, for battery applications, a buck converter be used to regulate the power. Here's a link to the recommended converter: http://www.mini-box.com/DCDC-NUC.
Hope this helps,
