Intel® NUCs
12307 Discussions
Can I use the internal power supply connector as a 12v power output?
JKoht
intel_PS.pngI would like to power a touchscreen (12v) from my NUC7I5DNBE board.
Can I use this internal power supply connector? Is there a better way to accomplish this?
Thank you.
Esteban_D_Intel
Hello JKoht,
Thank you for posting on the Intel® communities.
I would like to inform you that the Internal Power Supply connector of the board is mainly used as an alternative way to power the board, it works as an Input power connector as you can see in the Technical Product Specifications.
Therefore, the internal connector can't be used to power an external device.
I hope that the information provided answers to your question. If you need further assistance please let us know.
Esteban D.
Intel Technical Support Technician
JKoht
Thanks for the follow up Esteban!
I figured out a way to power my device off of the power supply.
Cheers!
