Intel® NUCs
Support for Intel® NUC products
12762 Discussions
Can NUC11PAHi5 use Optane H20?
Yongkee
Got both recently.  NUC has opdated with latest BIOS PATGL357.0041.  I believe I have followed the instruction here Intel Optane Memory H Series Installation & User Guide to install but somehow BIOS can only see QLC 3DNAND but not Optane portion of the disk.
I assumed it'd be a message display glitch, so went ahead to install windows10, then RST, etc.  During the whole time, never saw any indication that the system/OS found the existance of Optane drive.
Any suggestion?  Or should I just wait for newer BIOS?  Appreciate any help!  Thanks.
DeividA_Intel
Hello Yongkee,
Thank you for posting on the Intel® communities.  I understand you are having issues with your Intel® NUC 11 Performance kit - NUC11PAHi5.
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
2. Can you take a picture of the disk manager?
3. Can you take a picture of the Intel® Rapid Storage Technology disk options?
4. Do you have any RAID configuration?
5. If possible, provide the version of the Intel® Rapid Storage Technology.
Deivid A.
LeonWaksman
Hi @Yongkee
You are not the first complaining on H Series SSD not working in Panther NUC NUC11PAHi7 Can't use both a SATA and NVME drive.
Neither Optane support is not mentioned in this NUC specification.
Finally the Intel H Series SSD is not Included in the Validated Components List.
The above brings me to conclusion that Optane  is not supported on this NUC.
Leon
