Intel® NUCs
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
12540 Discussions
Can NUC11PAHi5 use Optane H20?
Yongkee
Got both recently.  NUC has opdated with latest BIOS PATGL357.0041.  I believe I have followed the instruction here Intel Optane Memory H Series Installation & User Guide to install but somehow BIOS can only see QLC 3DNAND but not Optane portion of the disk.
I assumed it'd be a message display glitch, so went ahead to install windows10, then RST, etc.  During the whole time, never saw any indication that the system/OS found the existance of Optane drive.
Any suggestion?  Or should I just wait for newer BIOS?  Appreciate any help!  Thanks.
DeividA_Intel
Hello Yongkee,
Thank you for posting on the Intel® communities.  I understand you are having issues with your Intel® NUC 11 Performance kit - NUC11PAHi5.
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
2. Can you take a picture of the disk manager?
3. Can you take a picture of the Intel® Rapid Storage Technology disk options?
4. Do you have any RAID configuration?
5. If possible, provide the version of the Intel® Rapid Storage Technology.
Deivid A.
LeonWaksman
Hi @Yongkee
You are not the first complaining on H Series SSD not working in Panther NUC NUC11PAHi7 Can't use both a SATA and NVME drive.
Neither Optane support is not mentioned in this NUC specification.
Finally the Intel H Series SSD is not Included in the Validated Components List.
The above brings me to conclusion that Optane  is not supported on this NUC.
Leon
