Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13491 Discussions
Can anybody provide me with a step by step process on how to install the IRST. I assume that the drivers have to be installed before you install the Win 10 system? Any help will be appreciated. TIA
TDean
New Contributor II
BHarr8
Valued Contributor I
Are you asking about the RST drivers?
What device are you installing them on and what are you using them for (RAID or Optane cache)?
TDean
New Contributor II
I am installing on an Intel NUC8i7HVK i7-8809 with 2 Samsung 970 Pro 512GB M.2 NVMe PCIe x4 SSD. I would be using them for Raid 0 or Raid 1, haven't made my mind up yet on that. I will be using Windows 10 Pro 1809.
BHarr8
I have the same unit and have RAID 0 setup.
Head here and grab both the f6flpy-x64.zip (unzip this into a folder and stick in the root of the flash drive you will be installing from) and SetupRST.exe files.
https://downloadcenter.intel.com/download/28400/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver-for-Intel-7th-8th-Generation-Platforms
Next head here and click 'PCIe (NVMe) RAID' to expand the directions.
https://www.intel.com/content/www/us/en/support/articles/000021493/mini-pcs/intel-nuc-kits.html
Those instructions will show you how to both use BIOS to setup the RAID and how to use that f6flpy-x64 folder during the Windows install process to install the RAID drivers.
Once on your desktop install SetupRST.exe if you want to manage your RAID setup although this step is optional.
TDean
New Contributor II
Excellent BHarr8!. Thanks alot!
