Intel® NUCs
12305 Discussions
Can get video resolution to 2560x1600
DL1
Trying to setup my 5th Skull Canyon which is being problematic with a 30" HP LCD. When installing Win10 initially the resolution is 2560x1600. When I start loading system drivers for the unit, the resolution jumps down to a max 1280x800. I have tried to load all the drivers manually and automatically with the Intel updater program. When it to load the latest 27-8-2018 graphics drivers it reports "This installation package is not supported by this processor type."
Here are the current driver details from Intel report:
- "Display"
Intel ® Graphics Driver Version:"1.7.22.0"
- "Intel(R) Iris(TM) Pro Graphics 580"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"1.00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) Iris(TM) Pro Graphics 580"
Link:" http://www.intel.com/content/www/us/en/search.html?keyword=Iris+Pro+Graphics+580"
CoInstallers:"igfxCoIn_v4534.dll, CoDeviceInstall"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmd64.sys"
Driver Date:"10/06/2016 05:00 PM"
Driver Path:"C:\Windows\system32\DRIVERS\igdkmd64.sys"
Driver Provider:"Intel Corporation"
Driver Version:"21.20.16.4534"
INF:"oem23.inf"
INF Section:"iSKLD_w10"
Install Date:"Not Available"
Installed Drivers:"igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll,igdumdim32,igd10iumd32,igd10iumd32,igd12umd32"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_193B&SUBSYS_20648086&REV_09\3&11583659&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"59 Hz"
Refresh Rate - Maximum:"59 Hz"
Refresh Rate - Minimum:"59 Hz"
Resolution:"1280 X 800"
Scan Mode:"Noninterlaced"
Service Name:"igfx"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) Iris(TM) Graphics Family"
I am not sure if am update display driver will fix the resolution issue but I will be in the right direction. How can I get the driver to work?
Community Manager
redham: Thank you for joining the Intel® communities.
Based on the report, since the computer is using Intel® Iris Pro Graphics 580, we can always try to install the Intel generic graphics driver version 25.20.100.6326:
https://downloadcenter.intel.com/download/28240/Intel-Graphics-Driver-for-Windows-10?product=88357
What is the model of the NUC?
Were you able to use that resolution before?
Alberto R.
Under Contract to Intel Corporation
Community Manager
redham: I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Alberto R.
