The Intel NCU NUC6CAYS comes with 2GB of RAM. But I was wondering if it would work well if I installing another 4GB RAM stick (with a total of 6GB RAM)?
Diego
- Tags:
- Intel® NUC 6th Gen
Hello drylight
Yes, you can install 4GB module in the second slot (with 2GB already installed in the other slot). It is advisable to choose memory from the list of tested and approved by Intel memory: http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC&productType=Mini%20PCs&productName=Intel%C2%AE%20NUC%20Kit%20NUC6CAYS http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC&productType=Mini%20… and http://www.cmtlabs.com/2012/memCertPartSearchResultsAll.asp?bNav=True&sManuf=Intel&outside=False&sMN=NUC6CAYS/NUC6CAYH&oSubmit=Search CMTL > Search > Tested Motherboard > Results
Hope this helps
Leon
Hello drylight
Hope this helps
Leon
Thank you, Leon. I'll be sure to check these out.
