Dear All,
Im not able to install any driver on nuc 7i5dnk2e.
OS: Win10 pro, x64.
e.g.: when im trying to install lan driver or gpu driver, the installer says "Cannot install drivers. No Intel(R) Adapters are preset in this computer.". I've checked, ethernet is enabled in bios.
I've tried several versions of eth driver for this nuc (22.X, 23.X, 25.X, 26X). Also tried older versions (oldest available is 22.X ). Also tried to extract the .exe file and update manually. Nothing works. No ethernet connection can be established, no driver can be installed. The same thing happens if im trying to install a gpu or chipset driver, the same error message appears.
I've tried to download and install the recommended "bundle" driver package, the same thing happens.
Can somebody help, how can i install an ethernet driver and make a connection?
Hello Eodnhoj
Please share with us the following information:
- Screenshots of the errors
- Was the NUC working properly before?
- Is this a clean Windows Install?
- Provide the Intel® System Support Utility (Intel® SSU) resiults:
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
- Click on the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click on "Next", then "Save".
David G
Hello Eodnhoj
Were you able to check the previous posts?
David G.
Hello Eodnhoj
David G.
