Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Can not recover BIOS
Hi
i just got my Intel NUC DC3217BY
i tried to update bios using a usb-stick, but for some reason it failed.
now the NUC tries to boot but goes black in a couple of seconds and does that over and over again.
i downloaded the recovery version of the the bios update and followed the instructions by removing the bios jumper etc, but nothing
happens.
What to do?!
/Daniel
Tags (1)
Highlighted
Re: Can not recover BIOS
Hello Daniel, I'm sorry to hear that you are having issues with your new NUC, would you please let me know which BIOS version did you tried to install on it?
In the mean please remove all the additional components such as SSD, memory and wireless.
Also, please do a clear CMOS. The following picture shows the correct way to do it.
Highlighted
Hi Sylvia!
i solved the problem by buying two new 1333mhz RAM-modules, the old ones were 1066 mhz
which i understand are not compatible with the latest BIOS update.
Highlighted
Perfect Danio!!! I'm glad to know you solved the problem.
