Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Can' t Access RAID Configuration on NUC5i5MYHE
Jump to solution
I'm trying to setup RAID on a NUC5i5MYHE. I'm following the instructions here http://www.intel.eu/content/www/eu/en/support/boards-and-kits/000020938.html RAID Setup Procedure for Intel® NUCs but pressing CTRL-I just results in a hung post screen.
I have several identical setups using this hardware and they all do the same thing.
Unit: Intel NUC NUC5i5MYHE
Mainboard Version: H47797-205
BIOS Version: MYBDWi5v.86A.0030.2016.0527.1657
RAM: 2 x Kingston KCP3L16SD8/8 Modules (P/N 9905428-417.A00LF, 1600MHz DDR3L 1.35v 8GB SODIMM)
Storage: Intel SSDSC2KW480H6 & Intel SSDSCKKW480H6
Has anybody else been able to access the RAID configuration menu on this unit?
Accepted Solutions
Highlighted
Re: Can' t Access RAID Configuration on NUC5i5MYHE
Jump to solution
It turns out there is another step required to be able to access the RAID setup.
There is a boot setting called Expansion Card Text and by default this is disabled. Once this was enabled the menu worked without a problem. It would be nice to see either the article updated with this additional step or the next release of the BIOS with this enabled by default.
Highlighted
Community Manager
Jump to solution
Hi Htechnology,
I recommend you to try it with another keyboard, and before you start the configuration please load default settings on the BIOS.
Please let me know how it goes.
Hellen.
Highlighted
1 View
Jump to solution
Highlighted
Community Manager
Jump to solution
Hi Htecnhology,
Thanks for this information. Sure, I have sent this suggestion to the appropriate team.
If there is anything else you need, please let me know.
Hellen.
