Intel® NUCs
Assistance in Intel® NUC products
13309 Discussions
Can’t make POST prompts go away
GlennStasse
I have a NUC 11 Bios PATGL357.0041.2021.0811.1505
i set the Bios to give me a prompt after POST saying hit F2 to get into BIOS or esc to continue booting. I have all my booting stuff squared away and I want to now skip the prompts. To save my soul I can’t turn it off. I went back to where I turned it on (Boot Display Configuration) and no combination of setting turns it off? I know something is working because I can make the logo appear and disappear.  None of the other keys seem to work now either. F2 and escape still do but F7, for instance does nothing that I can detect.
is there a way to go back to some default setting?
Power off (unplug) had no effect.
thanks….Glenn
GlennStasse
I solved this. The problem was the setting was on the "Boot Priority" page, not the Display page. The setting, which must be the one I turned on to get the prompts in the first place, is Bios Setup Auto Entry . Clearly my mistake!
GlennStasse
AndrewG_Intel
Hello @GlennStasse
We are glad to know that you were able to solve this and thank you for taking the time to share this feedback. Hopefully, it may help other community peers experiencing a similar issue.
Since the thread has been marked as "Solved" we will proceed to close it now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
