Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Can't power on D34010WYK in Akasa Newton H case
I have just bought an D34010WYK to be used as a HTPC. It works fine in it's original case but when I switched case to Akasa Newton H I can't power it on with the power button, I can see that the standby light is glowing green and have connected the cable to the front panel header on the motherboard but it won't boot, when I switched back to the original case again everything worked again.
Anyone know what might be causing this or should I get the Akasa case replaced?
Highlighted
New Contributor II
1 View
Have you connected the Akasa cable right (see Picture 'Power On Cable) and pressed the power on button on the Akasa front panel?
The green LED at the back means that Ethernet cable is connected.
Highlighted
1 View
I connected the cable according to the picture you attached and pressed the power button on the front panel but nothing happens.
With green led I mean the standby led on the motherboard not the ethernet port, it's the same led that is visible on top of the original NUC case.
Highlighted
New Contributor II
1 View
Then I would check every single wire of the cable (and even the switch) with a Multimeter to make sure the cable is properly done/mounted.
Highlighted
1 View
I would also check for case protrusions, etc. that could short something...
Highlighted
1 View
Thanks, I will do as you have suggested and start with checking every wire in the cable.
Highlighted
1 View
I have checked the cable and power switch with a multimeter now, there seem to be no connection when I push the button so I will return the case.
Highlighted
New Contributor II
1 View
It's OK. Anyway it's likely it's an Akasa problem.
