My NUC11 Enthusiast NUC11PHKi7 cannot pass the Windows 11 check, due to TPM 2.0 not exist. Can anyone please tell me any solution to fix it? or it is hardware issue cannot be fixed? Thank you very much!
Your nuc has PTT:
It may need you to update the bios. If that does not solve the issue, then the Microsoft check utility is likely faulty.
In the meantime, run TPM.MSC and report back.
[Windows 11 is the new Vista]
Your nuc has PTT:
