Intel® NUCs
12322 Discussions
Cannot Reset PC after BIOS update
rabbieb
Got the 895MB Download Bundle dated 12/18/2020 for my NUC7i7BNHXG which includes a BIOS update to ver 0083.
Ran that first using the Express option for Windows 10.
NUC now in "auto repair - diagnosing - cannot repair" loop and none of the recovery options work including both 'Reset PC' options.
Suggestions?
n_scott_pearson
Super User Retired Employee
In some cases yes, in other cases no.
I am sorry that my answer is so squishy, but I cannot do better. The problem is dependencies. If the dependencies are covered, then the apps will continue to run. If they aren't, then they won't. Since most dependencies are reflected in the Registry - which would have been reset - they have likely been lost. All you can do it try...
rabbieb
Can confirm BIOS update was successful and have access to Intel Visual BIOS.
None of the Recovery/Repair options function. Cannot System Restore from any of the 3 available restore points - problems writing from Registry. Cannot find an Image file.
Alberto_Sykes
rabbieb, Thank you for posting in the Intel® Communities Support.
In reference to this scenario, you mentioned, "Can confirm BIOS update was successful and have access to Intel Visual BIOS", so, just to make sure, there is no problem with the BIOS, you can access it normally and change the settings without any problems, is that correct?
If that is the case and the problem might be related to Windows* itself, then what we can try is to do a clean installation of Windows*, following the instructions from Microsoft's web site and using the registry key that you can access directly from the BIOS of the Intel® NUC itself, please back up any important information you might have on your system before trying this procedure:
https://www.intel.com/content/www/us/en/support/articles/000025593/intel-nuc.html
Albert R.
A Contingent Worker at Intel
n_scott_pearson
It may be that a portion of the BIOS configuration was modified by the BIOS update process. The user should confirm that setting like SATA Mode, UEFI Boot Enable, etc. are all set as they were previous to the BIOS update process.
rabbieb
OK had to do a clean Windows install. At least that's easier these days since Windows recognises the PC had a legal version installed previously. NUC is now functioning normally.
New question - is there a way to recover my apps and programs? The Program files are saved in a \Windws.old\ folder. Can I reinstall them from there or do I need to do clean installs of them all too?
n_scott_pearson
