Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Cannot detect microphone
When I plug my microphone in, the popup appears asking which device I plugged in. I select microphone, but still get no audio from it. Checking my audio setup, I don't see my microphone listed anywhere. Can someone help? I'm a streamer, and my webcam audio isn't good enough for my broadcasts. If it helps, I'm using a Zingyou BM-800 microphone, on a 3.5mm audio jack.
Highlighted
Re: Cannot detect microphone
Hello TMorg9,
In order to better assist you, could you please provide the following information?
1- Intel NUC full model:
2- Did this configuration work fine before? Is this a brand new Intel® NUC?
3- Have you tested the microphone on other computers? What is the outcome?
4- For reference purposes, please provide some screenshots showing the "popup" and the "audio setup" where the microphone is not listed:
5- Please run the Intel® System Support Utility (Intel® SSU) and attach the report to this thread.
5.1- Download the Intel® SSU and save the application on your computer.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
5.2- Open the application and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
5.3- To save your scan, click Next and click Save.
5.4- To attach a file, you must click the “Attach” option on the bottom left-hand corner of the response box.
Andrew G.
A Contingent Worker at Intel
Highlighted
Hello TMorg9,
If you need further assistance, please let us know. We will be glad to assist you.
Andrew G.
Highlighted
Hello TMorg9,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Andrew G.
