Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13517 Discussions
Cannot install Win 10 - Error "System Service Exception" Appears on Step 2 - 11 to 20 %. Also Error-Message: "Kernel-Security Error." What can be done?
MFran72
Used: New MS-Creater- on USB-Stick. NUC INTEL NUC7I3DNHE. With RAM Seven 8GB DDR4 2133MHZ CL15 NON ECC and SA400M8/240G Kingston A400 SSD 240GB, M.2 SATA
n_scott_pearson
Super User Retired Employee
Try turning off Secure Boot while you install the O/S.
MFran72
Turned off Secure Boot – same problem.
AlHill
And, you are certain that you made your usb stick from this link: https://www.microsoft.com/en-us/software-download/windows10
What bios version do you have?
Doc
MFran72
Yes, the USB stick was made with the MS Creator. The BIOS Version is DNKBLi30.86A.0064.2019.0524.1402
AlHill
That is not what I asked. Did you make the USB stick from the Link I provided?
You have bios 0064. THe latest is 0086 and can be downloaded here:
https://downloadcenter.intel.com/download/29464/BIOS-Update-DNKBLi30-86A-
When you install the OS, choose custom, and delete all partitions on the drive you are going to install W10 on, and select unallocated space.
Doc
MFran72
I used your Link – in a german version. Then i tried to update the bios as told her https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/Visual-BIOS-Update-NUC.pdf Unfortunately the stick is not recognized (I tried the F7-methold because i have no os installed). I have no idea what to to.
MFran72
So, I managed to update the bios. With the Win 10 from your link I tried 2 times. The Error comes at the installation process on step two: „Files are being prepared“. Two Error-Messages: 1) „IRQ no less or equal“ / „no access to installation medium“ . 2) „Failed NTFS Sys“. Blue Screen, New Start…
AlHill
The usb stick, to update your bios, must be formatted as FAT32, on a windows machine (not linux, not mac). Just put the 0068 bios file on the stick after you format it. The stick should be at least 8GB.
It also sounds to me like your current stick may be bad. Get a new stick.
On the OS install, unplug all unnecessary devices. Do this with a new stick.
Doc
MFran72
I used a new stick and made the installation stick on a different computer. Same problem, a few seconds later, at step 2, 23%. 1st time „System Service Exception“ At the 2nd time another error message: „atempted write to rom“. It now seems to me that some hardware is faulty. Board, RAM oder SSD. Any idea, which?
AlHill
I am thinking memory first, SSD second. If you can get some memory just to test, that would be great.
Doc
MFran72
It was the memory. I bought two ones, changed to the other and it works. Now the system runs three hours without any problem. Thanks for support, I learned a lot…
AlHill
Glad you have it working.
Doc
