Hello Members,
I didn't find anything about my problem, so I am asking here in the hope that someone can help me with this. I would like to modify the BIOS CMOS using iSetupCfgEfi64.efi. I have the latest downloadable version installed, but whenever I try to modify a setting, it fails. The same works from Windows using the iSetupCfgWin64.exe program. I suspect a bug in the EFI version, but there might be a workaround. Reading a value works fine, and I tried both with BIOS password set, and not set, but using the "password check bypass" option in the BIOS.
Anyone met this problem already? Any suggestions?
Sándor Rózsa
Thank you for posting on the Intel Communities.
If I may jump into the conversation, I would like to add the following:
Based on the screenshot that you have provided the version seems to be outdated, please download the latest version 5.05.04.0006 from the following link and let us know if the same issue happens.
Hugo O.
What NUC? What BIOS version?
Dear Scott,
Thank you for replying. The device is NUC11TNHi7 and the BIOS version is TNTGL357 0069.
Sándor Rózsa
I attach the screenshot of the error message I got when trying to execute the command.
Hugo O.
Dear Hugo,
Thank you for joining the conversation. It seems that I have downloaded the latest version, but forgot to update on the target. The newer version seems to have fixed this bug. The ticket can be closed.
Sándor Rózsa
Hello RózsaSándor
I am glad to hear that the issue is now solved and everything is working fine.
Hugo O.
