Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Cannot update Ethernet driver on NUC6I7KYK
Jump to solution
Intel(R) Driver and Support Assistant correctly reports that I have version 12.15.25.6712 of Intel(R) Ethernet Connection (2) I219-LM driver and suggests I upgrade to version 22.9. I perform the upgrade, but the driver remains at the same version and the assistant reports the same issue. If I upgrade again, the setup program runs in the maintenance mode indicating that the driver is already installed. I rebooted multiple times, uninstalled the old driver manually, etc, but nothing helps. All other drivers seem up-to-date. Any idea how to fix it?
Tags (2)
Accepted Solutions
Highlighted
Disregard the Intel(R) Driver and Support Assistant warning. Version 22.9 is the all driver package number, while 12.15.25.6712 is the driver number. It is bug in the Driver and Support Assistant that gives this warning.
Leon
Highlighted
Leon
Highlighted
Thank you.
