Does anyone have a recommendation for new Compatible Processor ?
What do you mean "compatible"? Explain your problem in detail.
You have a 6th gen desktop processor. In order to be used, a replacement processor must be socket, chipset and BIOS compatible. Only the designers of the motherboard can tell you exactly which processors are supported. Most motherboard manufacturers publish a list of supported processors. You must consult this list to determine your choices.
Hope this helps,
Hope this helps,
