After updating the Chipset driver of the NUC8i7HVK through the Intel Driver & Support Assistant, another driver popped up to update the Chipset Thermal subsystem - A131. After trying to update this driver, it doesn't get updated and this update is stucked every time I check for updates. Also the Driver Date appears very old "1/1/1970". Tried to update the specific part through the device manager, but it doesn't get updated from there also.
Is there a way to fix this issue?
Thank you.
You are not the first to report this. Others, and myself, have experienced the same issue, yet no fix is available at this time.
I will notify the management of the issue.
Doc
Seems like it is corrected now. The IDSA scan shows all updated.
Doc
