Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13487 Discussions
Compatibility problem NUC 11 22h2
Snackbar
Hello!
The latest Windows 11 22h2 has not been offered for unknown reason.
The WindowsPCHealthCheckSetup.msi doesn't have any incompatibility issue.
I have checked the registry, which someone posted
Computer > HKEY_LOCAL_MACHINE > SOFTWARE > Microsoft > Windows NT > CurrentVersion > AppCompatFlags > TargetVersionUpgradeExperienceIndicators > NI22H2
The ReadReason is None.
I tried installing the 22h2 with the Windows 11 installation assistant, however after restart it rolls back the installation without any error messages.
The model is NUC11PABi5, Bios: 0048, Intel Driver Assistant says no update available.
I have checked driver errors and sfc scan already. Other windows updates are installed.
Thank you for your help.
Jean_Intel
Hello Snackbar,
Thank you for posting on the Intel️® communities. I am sorry to hear that you are experiencing issues updating to the latest Windows version.
Jean O.
Jean_Intel
Hello Snackbar,
Thanks for waiting for a response.
Have you tried contacting Microsoft about this matter? Remember that this is an update from their Operating System and they may have more details about it.
Jean O.
Snackbar
Hello Jean!
Thank you for your reply.
I would like to report that my problem has been solved after several hours of investigation.
It was not a hardware issue.
I am writing my solution, maybe somebody can find useful information:
I ran a suggested Microsoft app named setupdiag which reported the reason of failed update with WindowsAssistant.
Error: SetupDiag reports rollback failure found.
Last Phase = Safe OS
Last Operation = Apply Drivers
Error = 0x80070002-0x20007
LogEntry: 2022-11-04 23:28:59, Error DISM DISM Driver Manager: PID=1648 TID=1676 Failed to import driver package 'C:\Windows\System32\DriverStore\FileRepository\eszig-md.inf_amd64_7dc225a8f03f2c88\eszig-md.inf'. - CDmiDriverStore::Import(hr:0x80070002)
The conflicting driver is a part of a governmental application which is obligatory to install to be able to work with the Hungarian electronic ID cards.
Surprisingly, uninstalling the software is not enough, the drivers had to be deleted manually from the DriverStore/FileRepository.
After deleting the driver, the WindowsInstallationAssistant went on without any errors.
Snackbar
Jean_Intel
Hello Snackbar,
I am glad to hear that the issue is now solved and everything is working fine. If you need additional information, please submit a new question, as this thread will no longer be monitored.
Jean O.
n_scott_pearson
Super User Retired Employee
Is there a web page that details this manual process?
