Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Compatible memory for the NUC8i7HNK
Jump to solution
I would like to purchase new RAM for my new NUC8i7HNK and I found two possibilities for about the same price:
- Corsair Vengeance SO-DDR4 16GB 2-Kit (2x, 8GB, DDR4-2400, SO-DIMM 260 pin)
or
- HyperX Kingston Impact Kit (2x, 8GB, DDR4-2666, SO-DIMM 260 pin)
Have somebody an advice for this?
Are booth modules compatibles with the NUC?
I think the HyperX DDR4-2666 can be usable in the NUC to and the frequency will be automatically reduced to the default 2400?
Thank you for the help.
padunand
AlHill
You can find tested/validated memory here:
http://compatibleproducts.intel.com/ProductDetails?activeModule=Intel%C2%AE%20NUC Intel® Product Compatibility Tool
Doc
AlHill
Doc
Community Manager
Thank you...
BBear
I used hyperx ddr4 2400 on my 7th gen NUC which requires 2133.
It should be fine if you buy the hyperx which is 1 level faster than required.
