שלום חברים
יש לי nuc8i3beh חדש. מנורת הדיסק מהבהבת צהוב כל הזמן לאחר הפעלת המחשב. האם זהו מצב נורמלי? תודה על העזרה
Shalom Elad,
I'm participating in this forum more than 4 years and this is the first post I see written in Hebrew (: . Since the support is provided in English, I'll answer in English. You are writing that you have new NUC8i3BEH and the HDD Activity LED is continuously blinking. You are asking if this is normal? Well, if your system works as expected, it is normal. This LED shows that there is an activity (write/ read) on the drive. It is quite common in Windows 10. You may run Drive Optimization which may reduce this activity.
Leon
in honor of. Intel Community
Your request to send a computer test report created by SSU software I tried to forward to you via the reply in the mail you sent me and it was not sent because there is no mail address I will ask for an explanation of how I pass the test results to you.
Regards Menachem Matityahu
Computer problem nuc 8i3BEH
Hi Menachem,
Just realized that your name is not Elad but Menachem (sorry for that). You have opened three threads for the same question. Now you are sending the SSU report to me while I was not asking for this. Any way the Intel Support Engineer @Sebastian_M_Intel is going to get it. He will be able to comment it only tomorrow (Monday), since today the support is closed. I can say that I don't see any thing wrong in your computer. As I told you the HDD Activity light is blinking because some updates are taking place. Could be that the Windows Security is performing scan. Is the LED still blinking in the same frequency as two days ago?
Leon
