Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13512 Discussions
Connecting touchscreen using eDP port
AMart141
I am trying to connect an LCD screen to the NUC7i7DN using the eDP port. I would like to connect to either the B156HAK3.0 or the NV156FHM-A21. I have attached the eDP pinouts for both monitors.
My question is do I just need to make a custom cable and match the net names from the NUC eDP port to the eDP ports on the monitors?
Do I just route the USB signals for the touchscreen to a USB header on the NUC?
Alberto_R_Intel
AMart141, Thank you for posting in the Intel® Communities Support.
In reference to your question, we will do further research on this matter, as soon as I get any updates I will post all the details in this thread.
Alberto R.
A Contingent Worker at Intel
Ronny_G_Intel
Community Manager
Hi AMart141,
I didn't quite understand the question, as you are already aware the pin out reference is available at the TPS, on page 51. the connector is 1X40 eDP connector: I-PEX-20455-040E-12, matching cable should be -I-PEX-20455-XXXT-YYYY, where XXX = number of poles (040T = 40-pin) and YYY = length (0500 = 500 mm)
Keep in mind that Pin 1 designator on board silkscreen is incorrect for the following headers:
USB 2.0, HDMI CEC, Serial Port, SATA Power and eDP. The pinout information and Pin 1 designators in TPS are correct for these headers.
Let me know if this helps.
Ronny G
Alberto_R_Intel
Hello AMart141, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Alberto R.
AMart141
Yes I was able to get it resolved. It was a pretty dumb question but I am new at this. I was able to build a cable and matched the net names from the monitor to the eDP port and everything worked.
Alberto_R_Intel
AMart141, Thank you very much for letting us know those results.
Perfect, excellent, it is great t hear that you were able to build the cable and that everything is working fine.
Any other inquiry, do not hesitate to contact us again.
Alberto R.
