Intel® NUCs
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11988 Discussions
Constantly Freezing nuc8i5
OKram1
I have a new nuc8i5 which constantly freezes after 3-5 minutes. Fresh WIN 10 install, all updates (incl. drivers from Intel (Iris, Wifi)), also tried different RAM (currently Corsair Vengeance), tried different SSDs (incl. a Crucial 500 m2 SATA) and even tried to go back to bios 51 and then up again to 56.
Also tried using different OS (Linix Mint, latest version) - no luck . . .
Thanks for any help/ideas.
Olaf
OKram1
Here's the tool file
OKram1
Short update: After I saw in the report file posted above, that the 2400MHz RAM was running at the Speed of the RAM I had built in before (Valueselect, 2133MHz), I've resetted the Bios via the on/off button and the Nuc identified the Vengeance @ 2400MHz correctly. It seems so far, that this solved the issue - at least it hadn't a single freeze since hours. Fingers crossed . . . .
