Hello, may i Ask about my Intel Nuc model 5i3ryk that has ang Countinous green blink its more about an hour…
until now its blingking.. so what can i do?
thank you for the response
Please explain yourself better. How did you get to this state? Describe this state better. Is it powering on? Is it booting to O/S (Windows/Linux)?
Have you tried shutting down and unplugging everything plugged into it (power supply, monitors, USB devices, etc.) for a few minutes?
If you can get into Windows, please download and run the Intel System Support Utility for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
Hello Istibantheiv
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, I am glad to see that fellow community members have the knowledge and they jumped in and helped. You may also find the Discontinued Products website (https://www.intel.com/content/www/us/en/support/discontinued-products.html) website helpful to address your request.
You can get the specifications and verify this product's discontinuance status at the Intel® Product Specifications website > Product Status > "Discontinued". https://ark.intel.com/
David G
