Community
cancel
Showing results for
Search instead for
Did you mean:
ALópe
Controladora simple de comunicaciones PCI
No puedo identificar a que dispositivo corresponde este aviso Qué driver es necesario ?
Tags (1)
n_scott_pearson
Super User Retired Employee
You need to install the Intel Management Engine Consumer Driver package.
ALópe
I forgot to tell I have a NUC6cayh I can´t find the driver for this model
n_scott_pearson
Oops, sorry. For the AY, you need to make sure you install the Chipset Device Software, Serial IO Driver and TXE driver packages.
ALópe
All those drivers are installed and working.
n_scott_pearson
Reinstall the Intel Chipset Software package. This time, instead of just double clicking on the SetupChipset.exe, open a Command Window (As Administrator!) at its folder and enter command "setupchipset -overall".
ALópe
I have done it but no results.
n_scott_pearson
Have you tried forcing Windows to scan for new devices?
ALópe
Lo he intentado pero no sé si lo he hecho bien, Windows no encuentra que dispositivo es.
captura de pantalla por si sirve de algo
Mitchell_R_Intel
Did you install the latest driver bundle from downloadcenter.intel.com or did you let Windows install drivers from Windows Update?
Here is a link to the driver bundle for AY:
https://downloadmirror.intel.com/DriverPackages/Intel-NUC-Kit-NUC6CAYS_Win10-64_Drivers.20171213.zip https://downloadmirror.intel.com/DriverPackages/Intel-NUC-Kit-NUC6CAYS_Win10-64_Drivers.20171213.zip
If you let Windows Update do the driver install, you will have to use the driver bundle instead. Windows does not install all of the drivers that the system needs.
ALópe
Thank you I installed all those drivers and nothing changes
