Intel® NUCs
12298 Discussions
Copying Linux install from one NUC to another
kendew
Hello.  I have two NUC8i5EHs.  I'm in the process of installing a highly customized Arch Linux system.  I'm interested in having the exact system on both systems.  The installation process is very time consuming, so ideally I'd like to copy the installed system from one NUC to the other. The SSD is virtually the same,  one a Samsung (MZ-V7E500BW) 970 EVO SSD 500GB - M.2 NVMe Interface Internal Solid State Drive with V-NAND Technology, and the other the Samsung 970 Plus.
. I am wondering if using the Linux dd tool is an effective way to do this.  Or if there might be a better way.
Hopefully someone has experience with this.  Much appreciated.
n_scott_pearson
Super User Retired Employee
Get a USB 3.0 NVMe adapter and then you can simply clone the drive. Here's an example: https://www.amazon.com/dp/B087BW2KYH.
Hope this helps,
AlHill
Sounds like a question for ...  the linux community.
n_scott_pearson
Hope this helps,
kendew
Thanks for replies.  I've also posted to Linux forums and have received good ideas,  but n_scott_pearson's reply was uniquely and especially helpful,  because it was so practical.
powerarmour
Valued Contributor I
@kendew
You can also just use the gnome-disk-utility, and from the options menu 'Create Disk image' from the drive you want to copy, save the image somewhere, then 'Restore Disk Image' back to another drive, and then expand any partitions as necessary, dead easy
Screenshot-from-2021-01-13-23-24-26
