Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Creating custom rom for Intel NUC with kernel building
I am tring to compile the source but i am getting following error
Traceback (most recent call last):
File "/usr/lib/pymodules/python2.7/
lunch/runner.py", line 103, in run
lunch_master = master.run_master(config_file, log_to_file=file_logging_enabled, log_dir=logging_dir, log_level=log_level)
File "/usr/lib/pymodules/python2.7/lunch/master.py", line 730, in run_master
execute_config_file(lunch_master, config_file, chmod_config_file=chmod_config_file)
File "/usr/lib/pymodules/python2.7/lunch/master.py", line 689, in execute_config_file
execfile(config_file) # config is plain python using the globals defined here. (the add_process function)
File "./config/.config/android-x86_defconfig", line 6, in
CONFIG_X86_32=y
NameError: name 'y' is not defined
if i change the kernel =y to ='y' error is solved but
my terminal does not proceed forward it gets stuck in
root@ubuntu-desktop:/home/ubuntu/android/androidjb# lunch ./config/.config/andid-x86_defconfig
-- At this stage no error is fired, i kept if for more than 8 hours as it is...
Thanks & Regards
Tags (1)
Highlighted
Re: Creating custom rom for Intel NUC with kernel building
Hi Perception,
I am sorry you are having problems with this. I recommend you posting your query at the following link:
https://software.intel.com/en-us/intel-developer-zone-responsive https://software.intel.com/en-us/intel-developer-zone-responsive
