Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Custom bios logo with latest bios KYSKLi70.86A
Hi
I just tried to update the nuc skull with my own custom logo - followed the instructions from the intel intrgator toolkit pdf and made a .bio file with my jpg - No errors.
After a restart i pressed f7 to go to the bios update screen and selected my newly created .bio file. It then restarts to a screen where i can press 9 to allow updating/upgrading. The nuc
tries to install the .bio file but restarts after 1 second without updating the bios logo. I have updated several other (older) nucs logos without problem.
Is the nuc skull really supported in the integrator toolkit and with bios logo update?
Community Manager
Hi skulluserdk: Thank you very much for contacting the Intel® NUC communities. We are sorry to hear the NUC is not working as expected.
In regard to your inquiry, yes, the Intel® Integrator Toolkit supports the Intel® NUC6i7KYK, as you can confirm on the list of products on the following link:
https://ark.intel.com/products/89187/Intel-NUC-Kit-NUC6i7KYK https://ark.intel.com/products/89187/Intel-NUC-Kit-NUC6i7KYK
Remember that the size of the picture cannot exceed 60Kb and should be:
Height - minimum 120, maximum 1080
Width - minimum 120, maximum 1920
Any further questions, please let me know.
Alberto R
Community Manager
Ok, thank you for replying
I tested updating the logo with the 3 jpgs(\Intel_Default_Splash_Screen\NUC) that comes with the integrator toolkit but still the same problem
Computer starts, I press f7, selects the .bio, computer restarts, I press 9 to accept, computer restart before completing the update, Logo not updated
The nuc is connected to a screen with HDMI and a usb keyboard is also connected. I use a 4 GB usb - fat32 formatted
Community Manager
skulluserdk: You are welcome. Thank you very much for providing those details.
Just to confirm, if you do a normal BIOS update to the latest version: 0050, using the F7 method, does it get installed properly?
https://www.intel.com/content/www/us/en/support/articles/000005850/mini-pcs.html https://www.intel.com/content/www/us/en/support/articles/000005850/mini-pcs.html
https://downloadcenter.intel.com/download/27119/BIOS-Update-KYSKLi70-86A- https://downloadcenter.intel.com/download/27119/BIOS-Update-KYSKLi70-86A-
If it does, please test the Intel® ITK application again to confirm if it works properly.
Alberto R
Community Manager
One of the first things I did when I recieved the skull was to update the bios to version 0050. I used f7 to update to 0050. After that I installed Windows 10 and updated everything. Then i tried to update the bios logo - first creating a custom .bio with ITK with this:
"ITK6.efi –b –x skull.bio –il customnuc.jpg". I then rebooted and pressed f7 and selected the skull.bio file with the new logo. And then I get the error mentioned above
Community Manager
skulluserdk: Thank you very much for letting us know that information. We will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Alberto R
Community Manager
skulluserdk: I just received an update on this matter, actually on the Intel® NUC6i7KYK it is not possible to make a custom bio file with an image, you need to use an existing bio file (KY0050.bio) and use that one to create a custom BIOS with the following command: ITK6.efi -b -x customerbiosname.bio -ib KY0050.bio -il imagedesired.jpg
Also, if you have the option, please test the tool using a jpg image.
Alberto R
Community Manager
OK, thank you for the update - I will try the solution and report back
Community Manager
Just an update, It works Tested with the new comandline and updated/reflashed the bios with the new bios(with new logo) without problems
Community Manager
skulluserdk: You are very welcome. Perfect, excellent, that you very much for letting us know that information. We are glad to hear that the application is now working properly.
Any other inquiry, do not hesitate in contact us again.
Alberto R
