Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
D34010WYK USB host controller
Hi all,
I see that the NUC has 3 internal USB hubs:
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
However, it seems no matter which port I use for plugging an USB2 device (a TV tuner), it gets plugged in bus 002.
Bus 002 Device 004: ID 2013:024f PCTV Systems nanoStick T2 290e
If I plug in an USB 3.0 device in the same physical port, it will be connected to bus 003.
Bus 003 Device 002: ID 174c:5106 ASMedia Technology Inc. Transcend StoreJet 25M3
Before I start to fiddle with the NUC, I'd like to ask if the internal USB header is connected to the same bus as the ports in front/rear? In other words, will all USB 2.0 devices always share the same BUS on the NUC?
Highlighted
Re: D34010WYK USB host controller
The reason why I'm asking, is that I have two HD TV tuners that both work alone fine, but if I plug in both, neither of them works ok. I've ruled out power issues already by using a powered USB hub, but next I'd like to plug the tuners into different buses to see if that could help.
Highlighted
Trsqr, I'm checking with my expert contact for other ideas. I'll let you know what I find out.
