Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
D54250WYK screen problem
Jump to solution
I have the above nuc. I don't know what happened but the graphics no longer display on the monitor. When I press power, I can hear the unit turning on but nothing is shown on the screen. The monitor says no signal. I thought maybe the msata drive or memory died so I went and bought a replacement. After putting a brand new msata and memories into the unit, same problem. Nothing shows on the screen. Does anyone know what's going on?
Robert
Accepted Solutions
Highlighted
Hello Robert,
-Is the Power Led illuminated when you switch the unit ON?
-Can you try other video cable and/or other video input in monitor (i.e. Display Port or HDMI)?
-If you don't see any video output at all (even not an Intel logo during boot), try to recover your bios: https://www.intel.com/content/www/us/en/support/boards-and-kits/000005532.html BIOS Recovery Update Instructions for Intel® NUC and
https://www.youtube.com/watch?v=ZAMLk62Pb9s BIOS Recovery Demo | Intel - YouTube The latest bios file WY0045.bio download here: https://downloadcenter.intel.com/download/26632/BIOS-Update-WYLPT10H-86A-?product=76977 Download BIOS Update [WYLPT10H.86A]
Hope this helps
Leon
Highlighted
Hello Robert,
Hope this helps
Leon
Highlighted
Super User Retired Employee
For the most part, I agree with Leon. My prioritized list of things you should try is as follows:
  1. Perform a CMOS reset. This is detailed here: http://www.intel.com/content/www/us/en/support/boards-and-kits/000005805.html Intel NUC Clearing CMOS.
  2. Perform a BIOS recovery using the latest available BIOS. This is detailed here: http://www.intel.com/content/www/us/en/support/boards-and-kits/000005532.html?wapkw=bios+recovery Intel NUC BIOS Recovery Update Instructions. Leon's link to video showing process is good too.
Highlighted
Hi Leon,
Yes the power led is illuminated.
And yes, you are correct. Changing the video cable fixed the problem. I am getting video output again. That would be the last thing I would think about changing. How could a cable gone bad? I don't get it. Does this happen often?
Thanks!
Robert
Highlighted
Thanks N. Scott. Changing the video cable helped. Don't know why but it did.
Robert.
