Intel® NUCs
Assistance in Intel® NUC products
12983 Discussions
DCCP847DYE Ran for an hour now fails to POST
LAllh
I just built a DCCP847DYE with 2 GB RAM and a 525 series 30GB drive and no wireless card installed. Worked perfectly for an hour, then started tripping offline for a few times. Now it wont even post, Fan only kicks on fo a sceong while power button held down. Help me Obi-Wan Kenobie, your my only hope!
LHill_Intel
Hello Larry_A,
You appear to be experiencing the classic symptoms for the issue described here:
http://www.intel.com/support/motherboards/desktop/sb/CS-034326.htm http://www.intel.com/support/motherboards/desktop/sb/CS-034326.htm.
Lois H.
Intel
LAllh
Yes I saw that and thought the same thing, but when I removed the SSD to try and boot from a thunbdrive I get the same result. It will not even POST. Shouldn't it boot with no SSD? When I try the thumbdrive LED flashes once and nothing else happens. No bios screen, etc. If I hold the button down the thumbdrive LED flashes on and off for as long as I hold the buttion. I have tried clearing the CMOS and taking the BIOS jumper off to get a BIOS recovery upgrade from a thumbdrive but nothing gets me to POST.
LHill_Intel
Hi Larry,
It sounds like you do have a defective unit that needs to be replaced. The quickest way to get a replacement
would be through your place of purchase. If that is not possible, you can send an email to Intel Customer
Support (http://www.intel.com/support/mailform/desktop/nuc/emailsupport.htm http://www.intel.com/support/mailform/desktop/nuc/emailsupport.htm) for further assistance.
When requesting warranty replacement, you will need to include the following information:
NUC model
Serial number and SA Number (found on a barcode label on the bottom of the chassis)
Shipping information
Phone number
Email address
Please also reference this community thread for the warranty agent to review.
Lois
