Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
DG41TY usb ports problem with 2,5" hdd
hi
I have a problem with my board (DG41TY) since i replaced it.(It had a vga problem - in warranty).
Since then, usb ports don't work with 2,5" HDD (samsung & WD) that works in other pcs..
The 2,5" disks seem to take litle power... , but they don't start working ,like they are crashed ...
Usb ports works with keyboards , usb sticks ...
They don't see 2,5" HDD ..
Any ideas ?
I checked BIOS ...
Highlighted
Valued Contributor II
gediak wrote:
I checked BIOS ...
Is it the latest version for your board? Perhaps the earlier boad had a different BIOS version or hardware (AA) revision which provided more power to the USB ports (or at least more reliable power). Self powered USB HDDs can consume alot of power from a USB port especially on spin up (compared to say a thumb drive which doesn't have this problem) so I'd imagine your drive currently isn't being fully powered when it needs it and thats whats causing the problem.
Is there any way these USB drives can have their power augmented or supplied through an additional power socket on the case and if so can you try powering them that way?
