I have Intel DN2820FYK, the previous system had a issue, got a replacement from Intel, with this NUC not able to go to the BIOS settings by F2 key at startup. Tried the BIOS recovery steps described in Support Page, there is no difference, the BIOS seems to be locked. Can I access the BOOT order to change it to USB key using keyboard shortcut and anything i can try to get into the BOOT. Any help in this regard is appreciated.
Hello Srinivasg12
Thank you for your contacting us, I understand that you are having issues with the replacement that your local warranty team sent.
I have sent you a private message, please go ahead and take a look at your inbox.
I hope this helps.
Diego S.
