Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
DP55KG High pitched sound coming from the board
Did a quick search and couldn't find any info on this.
I have a high pitched sound comming from the board. I first thought it was one of the fans. I unplugged all the fans and the hard drives and the sound remains.
I an not RMA the board since my 30 days are up.
Anyone had this issue?
DP55KG
i5 750
Corsair H50 cpu cooler
4gb Corsair Dominator pc3-12800
Antec P180
OCZ 700w ps
ATI HD5670
Tags (1)
Adolfo_S_Intel2
Since the motherboard does not have any movable parts it is very unlikely that the motherboard makes that noise, it could be the processor fan, so I would recommend testing the processor and fan/heatsink in another motherboard to see if the issue follows this itmes.
MWong22
New Contributor II
this problem is quite rare to others esp you.. however i have encounter many times..
if that the case..
pls RMA the Mainboard to Intel asap.
pls tell Customer Service about the problem too..
Community Manager
Thanks fir the replies guys, I just got the phone with tech support and there was no problem getting a replacement board. I did a little more research found a couple more posts with this same issue. BTW, I got m board from Newegg just over a month ago. I just didn't have time to build my system until a few days ago so when I realized what the problem was, it was already too late to exchange it, thats what I get for procrastinating.. I hope I don't get another whining board lol.
MWong22
New Contributor II
ps: the whinning sound is coming out from one of the crystal fix on your mainboard. perhaps it is a faulty crystal.
Community Manager
Update
Yup... It was the board. I finally got a replacement las week and noise is no more.
