Community
cancel
Showing results for
Search instead for
Did you mean:
HOste1
DSAServiceHelper: Repeated installation of LAN driver 12.15.25.6
There is an endless loop in the installation request of the actual LAN driver.
It seems that the service helper isn't able to detect the installed version or the new driver package has an old version number...
In my case the wireless driver was updated correctly, after reboot only (and again) the LAN driver schould be installed.
Holger
Community Manager
Hi kho,
Thank you for bringing this information to our attention, let me help you on this matter.
I would like to know more about your hardware configuration. I need the model number of your system or please run the following utility and attach the results.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Looking forward to hearing from you.
Allan J.
HOste1
Hi Allen,
I run the SSU tool and save the results.
But I see no possibilty to attach a file in this replay.
So I put the content inline
# SSU Scan Information
Scan Info:
Version:"2.5.0.12"
Date:"10.03.2017"
Time:"00:00:13.2425011"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"Intel Corporation"
BIOS Mode:"Legacy"
BIOS Version/Date:"Intel Corp. BNKBL357.86A.0052.2017.0918.1346 , 09/18/2017"
CD or DVD:"Not Available"
Embedded Controller Version:"8.9"
Platform Role:"Desktop"
Processor:"Intel(R) Core(TM) i5-7260U CPU @ 2.20GHz , GenuineIntel"
Secure Boot State:"Not Available"
SMBIOS Version:"3.0"
Sound Card:"Intel(R) Display-Audio"
Sound Card:"Realtek High Definition Audio(SST)"
System Manufacturer:"Not Available"
System Model:"Not Available"
System SKU:"Not Available"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"22.20.16.4771"
- "Intel(R) Iris(TM) Plus Graphics 640"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"1,00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) Iris(TM) Plus Graphics 640"
Link:" http://www.intel.com/content/www/us/en/search.html?keyword=Iris+Plus+Graphics+640"
CoInstallers:"C:\Windows\System32\DriverStore\FileRepository\ki124278.inf_amd64_e45370788b56f38f\igxpco64.dll, CoDeviceInstall"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmd64.sys"
Driver Date:"08.13.2017 02:00"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\ki124278.inf_amd64_e45370788b56f38f\igdkmd64.sys"
Driver Provider:"Intel Corporation"
INF:"oem39.inf"
INF Section:"iKBLD_w10_DS"
Install Date:"Not Available"
Installed Drivers:"igdumdim64,igd10iumd64,igd10iumd64,igd12umd64,igdumdim32,igd10iumd32,igd10iumd32,igd12umd32"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_5926&SUBSYS_20688086&REV_06\3&11583659&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"60 Hz"
Refresh Rate - Maximum:"59 Hz"
Refresh Rate - Minimum:"29 Hz"
Resolution:"2560 X 1440"
Scan Mode:"Noninterlaced"
Service Name:"igfx"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) Iris(TM) Graphics Family"
- "Memory"
Physical Memory (Available):"12,93 GB"
Physical Memory (Installed):"16 GB"
Physical Memory (Total):"15,89 GB"
- "BANK 0"
Capacity:"8 GB"
Channel:"ChannelA-DIMM0"
Configured Clock Speed:"2133 MHz"
Configured Voltage:"1200 millivolts"
Data Width:"64 bits"
Form Factor:"SODIMM"
Interleave Position:"First position"
Manufacturer:"859B"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"CT8G4SFD8213.C16FBD1"
Serial Number:"A80EC5E0"
Status:"Not Available"
Type:"Not Available"
- "BANK 2"
Capacity:"8 GB"
Channel:"ChannelB-DIMM0"
Interleave Position:"Second position"
Manufacturer:"859B"
Serial Number:"A80EC7AC"
- "Motherboard"
BIOS:"BIOS Date: 09/18/17 13:46:57 Ver: 05.0000C, INTEL - 34"
Caption:"Hauptplatine"
Community Manager
Hi kho,
Thank you for the report. I appreciate it.
Based on the information, I noticed that your computer is currently running the latest LAN driver for the Intel® Ethernet Connection I219-V.
The latest should be 12.15.25.6 as shown on the picture attached, this is the same driver version from your computer.
I have tested the following driver version
https://downloadcenter.intel.com/download/26481/Intel-Gigabit-Ethernet-Network-Connection-Driver-for... https://downloadcenter.intel.com/download/26481/Intel-Gigabit-Ethernet-Network-Connection-Driver-for...
Hope it helps.
Allan J.
HOste1
Hi Allen,
thanks for your info. But it didn't help...
I've download and installed the above driver, the version in the device manager after installing is the same as the version before: 12.15.25.6.
And the DSA tool (I've started a rescan) still wants to reinstall this driver.
Which property at which location does the DSA check in the PC configuration (the driver version in the SSU output (see above) seems to be correct)?
Holger
Community Manager
Hi kho,
Thank you for the update. I will report this matter internally, thanks for the feedback.
In the meantime, since the report shows that you are currently running the latest LAN driver, there is no need to get different version for now.
Allan J.
HErwy
Similar problem here: Got Version 12.15.25.6 of Intel Ethernet Connection I219-V and cannot update to DSA-recommended Version 22.7.1 all attempts failed even deinstallation failed. Always end up with 12.15.25.6
n_scott_pearson
Super User Retired Employee
The installation packages (like 22.7.1) include a set of drivers that support a number of hardware MAC and PHY solutions. The version numbers for these individual drivers will vary, depending upon the number of versions of that driver that have been necessary. Do not, even for a minute, think that, after the package is installed, the version number of any driver installed is going to be (in this case) 22.7.1. Further, two releases of the installation package could contain the same version of a particular driver (if it doesn't need to be replaced, it doesn't get replaced). Thus, the installation of an upgrade package could very well overinstall with the same version of a particular driver. This does not mean that something has gone wrong.
