Intel® NUCs
Support for Intel® NUC products
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
12538 Discussions
Dealing with Driver Options
Kupuna
The NUC:
NUC8i7HVB
VERSION: J68196-602
WAS “HADES CANYON”
SERIAL: BTHN0180084H
Network connections
I have a variety of Intel network resources in my NUC, only one is being used.
That is my Intel Ethernet connection 1219-LM which connects to my router.
It is connected to I a Linksys EA7300 handling my current networking.
An Intel 1210 Gigabit Ethernet network connection is unused (not a problem)
Intel Dual Band Wireless – AC 8265  “Not operational” “Disconnected”
An unnamed “Bluetooth Network Connection” shown as  ” Not operational”
Two Microsoft (active) Wi-Fi Direct Virtual Adapters are also listed. (Windows 10)
I assume that the Linksys is taking care of Bluetooth and WiFi?.
Finally—The question: Am I using my NUC resources effectively? Could the NUC take over the WiFi, Bluetooth and Network tasks without using the Linksys router, or is the router more flexible or perhaps it takes some of the processing load from the NUC?
The same sort of question goes for the graphics and audio. I have a listing of:
For Audio
               Intel Display Audio
               AMD High Definition Device
               Realtek High Definition Audio
For Display:
               Intel HD Graphics
               Radeon RX Vega M GH
How do I choose or activate these resources-or can I? Is everything automatically selected?
Finally, Thanks for your patience in dealing with these questions. I consider myself about a 7 on a ten point scale of computer literacy, but this sort of information has proved very hard to dig out.
Greg Schultz
JosueO_Intel
Hello Kupuna,
Thank you for posting on the Intel communities.
In this case, it seems that the Intel® NUC is working as expected and not having any issues.
Regarding your inquiries about if you are using the resources effectively if you are not using some devices, you have the possibility to disable them in the BIOS. For example, if you are not using the LAN port of the NUC, you can disable it so that the NUC redirects those resources to other devices.
It is important for you to know that we don't recommend disabling video, audio, or any device that is necessary for the proper functioning of the NUC.
Josue O.
JosueO_Intel
Hello Kupuna,
Josue O.
