I'm looking to use the NUC Hades Canyon for Deep Learning Inference. I don't mind which framework specifically (tensorflow, torch, caffe, etc) but what I'm looking for is GPU support with the Vega M. Obviously I could use the CPU or Intel GPU, but I'm trying to figure out how to use the Vega M GPU.
Can anyone advise on the best framework that specifically leverages the Vega M GPU inside?
The frameworks I have found seem to be incompatible:
- OpenVINO: Only supports the Intel CPU/GPU inside the NUC, seems like it won't use the Vega M
- ROCm: Does not support Vega M
- CUDA: Doesn't work without NVIDIA hardware
- Tags:
- Deep Learning
Hello JMILL597,
Thank you for joining this Intel Community.
We apologize for the inconvenience, but we will not be able to address this inquiry properly.
We recommend you to reach out to AMD Developers: https://developer.amd.com/
Wanner G.
Under Contract to Intel Corporation
