Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Desktop Board DH55TC Max Memorie RAM Upgrade?
Hello everyone!
I need help in order to upgrade correctly my memorie RAM on my pc with Intel Desktop Board DH55TC, the board have 4 slots for DDR3, i want to be sure if is possible to add 4Gb DDR3 DIMM 1333MhZ in each slots? so in total will be upgrade until 16 GB ram since is the maximun available for the serie? ... by the way my OS is 64 Bits with processor intel i7
Thanks in advance for you help!!
Best regards.
Jose A.
Tags (1)
Highlighted
Re: Desktop Board DH55TC Max Memorie RAM Upgrade?
I found that adding 4 memory sticks into this board decreases the memory voltage below 1.5v (1.42V in my case).
This works, but not always. After about 6 months with spurios errors, I decided to remove 2 sticks (now for a total of 8GB). The memory voltage increased to 1.52V and things look a lot better now.
I tried various brands, currently I'm using Kingston valueram types (4gb, 1333)
Highlighted
Community Manager
Thanks for your advise!
