I installed a new 1TB Intel 760p drive as the second M2 drive in NUC6i7KYK (Skull Canyon). The bios sees the second drive of the right size, but thinks it is a second Samsung 960 Pro.
I presume this is some bios problem, probably not reading the manufacturer code correctly from the second M2 drive.
However, I don't want to go further if this is going to be a problem.
Anyone seen this already?
Remove the Samsung SSD. Leave only the second slot populated and check if bios is recognizing the Intel drive. Are the both slots enabled in bios (Advanced>Devices>PCI)?
Leon
