Intel® NUCs
12330 Discussions
Disable Driver Signature Enforcement
NSanc3
I have a problem because need to work with ​Disable Driver Signature Enforcement but for boot policy or BIOS configuration I can not Disable Driver Signature Enforcement.
Somebody could help ? ​
AlHill
What is the model number of your NUC?
Doc
NSanc3
model number : NUC8i7BEH
intel(R) Core(TM) i7-8559U CPU @ 2.70GHZ
AdrianM_Intel
Hello NSanc3,
Do you still need assistance? if so please confirm the following:
Are you trying to disable secure boot Keys exchange key (KEK) and (DB) database key from the BIOS?
May we know why would you like to do it?
Adrian M.
NSanc3
yes I still need it because I use some Visual estudio application that to run need to have window in test mode that means Disable Driver Signature Enforcement .. i know how to do it because i did in other pc but in this pc does not work because there is some boot or bios setting that not alow me .. even command in cmd does not work to disable it.
please if could help me with that because i really need .
thanks
kinds regards.
AdrianM_Intel
Hello NSanc3,
Thank you for your reply.
I would like to know what is the command you are running and if you can provide us all the instructions to run it.
It seems this is more related to the Operating System instead of the BIOS.
Adrian M.
AdrianM_Intel
Hello NSanc3,
Were you able to check the previous post?
Adrian M.
NSanc3
Hello AdrianM
sorry for the delay .
there are few differente way to do it and I tried all of them:
1) under start up advance setting there is option -> 7 at the Startup Settings screen to activate the “Disable driver signature enforcement” option.
2)by command : bcdedit /set testsigning on
bcdedit.exe /set nointegritychecks on
thanks
AdrianM_Intel
Hello NSanc3,
Please allow us some time to update the thread and check these commands.
Adrian M.
A Contingent Worker at Intel
Ronny_G_Intel
Community Manager
Hello NSanc3,
I was able to run the command: bcdedit /set testsigning on and I got "Operating completed successfully" result on the screen but this is as far as I went with this testing.
I would recommend that you reach out to Microsoft* support for more questions around this issue, this is more of an Operating System type of inquiry and falls out of our scope of support.
Ronny G
